ls/vtec questions
Unless your boosting the setup, running the stock ls pistons would be a waste of your time as the compression would be in the 9.5:1 range.
For an all motor application you should install jdm itr or p30 pistons to put you in the high 11.8:1 range.
compression is in the 9.5:1 range with the stock ls head already.....remember the combustion chambers of the vtec heads are MUCH smaller than the ls one, so its going to give a bump in compression (hence the near 10.0:1 compression with the stock ls pistons). with a thinner head gasket and good bolt ons, 170 hp to the wheels is very reachable with a good tune....
10:1 vs 11.5:1 on an all motor 81mm setup makes a nice amount of difference.
yup
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
