Compression Question...
Old Apr 7, 2007 | 07:57 AM
integra's Avatar
90% grind 10% sleep
Originally Posted by rangcrx
this is far from true msd are one of the best wires proven..but that would have nothing todo with it....useing that stock cams is a BIG factor i mean come on your just boosted you compression like 3Points with that little lift cam still pulling in the same air/fuel there are many things to check but i would not get my hopes up just throwing in high copmpression pistons
Im just saying i have had the same problem and it was the shitty MSD wires. yea they may work good but they pop out.
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
Originally Posted by THE_ONE
Old Apr 7, 2007 | 09:06 AM
Pyroproblem's Avatar
Porsche Tech/Honda Tech
Originally Posted by civicized
1. If plug wires are blowing out, could be a leak past the valve cover seals.
2. If John tuned it, I'm sure your timing is OK or he would have said something.
3. If you jumped your compression up significantly and you are on the stock cam, that could be your main power issue. Cams and pistons should be viewed as a package. You can lose power by your engine working against itself with high compression and too little cam to bleed off compression. In short, your motor may be straining to put the squeeze on the air/fuel, killing crank inertia and robbing power. This is why dynamic compression is a more important number than static.
Longer duration, bigger lift cams will allow some compression to bleed back into the intake on the compression stroke.
Think of it this way: you don't boost compression to get more compression for its own sake, you boost compression because you need more of it to run bigger cams. You left that part out of your upgrade package. Your engine is saying, WTF?
I couldnt agree more!!!
Now residing in Atlanta.....
Old Apr 7, 2007 | 06:03 PM
bigmike1's Avatar
2006 SINGLE CAM LOL
valve cover seals might be bad where the spark plugs go! check that
Best Honda Slogan Made By Greg
"Ur Boosted B series
Dosent Have A Chance
Agianst My K On Spray"
B SERIES
D SERIES
AIM : Goodfellas727
R.I.P.
Pablo 'Fathead' Garcia
Always will be remembered!
Old Apr 7, 2007 | 08:37 PM
TSX24L's Avatar
did you just make a funny? wow. ive always pictured you as a serious to the point no bs person.
Old Apr 7, 2007 | 08:45 PM
civicized's Avatar
The only thing I take seriously is fun.
Old Apr 8, 2007 | 11:03 AM
omgwtfbbq!'s Avatar
I race sailboats
Amen.
Bitches don't know about the twin turbo
BLACK FENDER PART OUT
