???what Swap???
Old Mar 26, 2007 | 09:32 AM
D2.4P's Avatar
Default ???what Swap???
I have some money to blow... Ive been tossing back and forth the idea of putting a K motor on boost into a hatch, or building a B and putting it on boost in a hatch
Im Most likely going to get rid of the eg I have now and get an ek
Im going to be doing alot of the work myself as far as the swap and the wireing goes..
How hard is the K swap into the hatch and how much am I lookin at with a reliable K on boost?
What would you do??
Old Mar 26, 2007 | 09:49 AM
-campy-'s Avatar
well a k on boost is gonna be fast as fuk but its also gonna be very costly umm i cant remember the guys name on here he has a a boosted k in a coupe damnit i cant remember....... imo i think that you should spend the money and boost a single the correct way they can be very fast they are a few making 500whp out of a single also and a lil cheaper to build but that is my oppion sohc ftw
Old Mar 26, 2007 | 09:52 AM
YARO's Avatar
Smith & Wesson Protected.
IMO get a gsr engine and boost/built that.
-Induction Performance ALPHA Tuned.
-ROQUE MACHINE SHOP For ALL your fabrication needs.
Old Mar 26, 2007 | 10:30 AM
elitist's Avatar
TR Balla Donor Supreme
H22! If you live anywhere near Springhill or New Port Richey let me know and I'll give you a ride in my na h22 hatch and that'll make up your mind for you
Old Mar 26, 2007 | 10:48 AM
D2.4P's Avatar
Im in Coral Springs right now movin up North soon....
I had a friend with a built H in a hatch.... it was nasty but he was going to axels and mounts like a bitch
I wanted the k on boost bc i thaught it would be different and fun
but the built gsr sounded fun to
How hard is the k swap to do yourself if you have the mounts?
Old Mar 26, 2007 | 11:55 AM
-campy-'s Avatar
go to kswap.org that should answer ur ?'s gsrcorey has a supercharged h22 in a hatch that only makes 220whp derka has a all stock well he has a skunk2intake manifold but anywho turbo single that makes 238whp and i am building a single that will hopfully be in the 3's so like i said it like life ya wanna be tied down to a gurl no stay SINGLE hahahahahahahaha sohc ftw
Old Mar 27, 2007 | 10:20 AM
elitist's Avatar
HCP mounts are guaranteed for life and I have never heard of anyone breaking one. As for axles, the HCP mounts als prevent axle bind and I very very rarely hear of axles snapping. The Hasport mounts and Avid mounts both create alot of axle bind which is where that is coming from. I know of me and 2 other H22 eg hatch owners who have never had any major problems and is about as reliable as possible. I personally have never had any problems period... the car has been driving perfectly every single day without one second of down time.
Old Mar 27, 2007 | 10:41 AM
PooN_Lude's Avatar
The new Hasport EGH2 mounts don't create axle bind like their old mount kit.
Old Mar 27, 2007 | 11:20 AM
doeboy's Avatar
the difficulty depends on your fabrication and wiring skill. its a hard swap, expensive, but completely worth it in the end. im starting a all motor k ej1 as soon as im all the way moved into my pops house in florida.
1992 honda civic cx 2.0l
steeeeerrrrnss are gone
http://www.myspace.com/drew_doeboy
Nikon D50 w/ kit lens / Tamron 70-300mm DI LD macro AF/Nikkor 50mm 1.8f/Nikon SB-600 speed flash
Old Mar 28, 2007 | 05:56 AM
typeronblades's Avatar
A k-series would be nice but it all depends if you got the time to do it that is one swap you can not rush and the price will depend on how much you plan on boosting your k-series motor are you going to build the motor or leave it stock i know na200whp is running a k-series beast on boost if you actually do it and you need parts you can talk to civic5133
