cold start idle issue
im having issues with my honda when starting when its cold. i have to give it gas to start it and keep giving it gas to keep the car from stalling until the car warms up. also, while im holding the gas to keep the car running the idle is jumping up and down. but once it warms up its fine and starts fine.
car is a 94 cx hatch with a GSR swap. mods are intake, exhaust, and chipped ecu.
any insight on what it could be? any help will be appreciated.
98 E36 ///M3 Sedan
07 Civic Si Sedan
98 E36 ///M3 Sedan
07 Civic Si Sedan
What ecu eprom chip is the car running on ?
Does the check engine light turn on then turn off when you first turn the key to the on position ?
Resetting the ecu won't effect a thing on an obd1 vehicle that is not throwing a code.
admittedly pwned
__________________________________________
www.floridasportsman.com
Originally Posted by P057
"Wow I had a hard time understanding that... but from what I gather you found an open-box item that wasn't cheaper. You bought it anyways. You then called someone a dumbass while making fun of their misfortune of losing a job as you were leaving the store?
I'm surprised you were able to get out the store with that big "SUCKER" sign affixed to your back. "
once it warms up, the car runs smooth and perfect.
98 E36 ///M3 Sedan
07 Civic Si Sedan
98 E36 ///M3 Sedan
07 Civic Si Sedan
