After tranny swap..5th gear is missing
Old Mar 24, 2007 | 05:08 PM
luvsracin87's Avatar
turbo hhhmmmm?
check the linkage at the tranny and make sure the shifter is bolted tightly to the linkage
Steve: (813) 810.4146 <~ call or text
Old Mar 24, 2007 | 05:20 PM
MAYMAY's Avatar
thanks for the advise.i will be sure to check on it tomorrow morning..
Old Mar 24, 2007 | 06:03 PM
RITZ7's Avatar
is a legend.
sorry about your luck on your tranny just make sure everything is tight and secure,and g/l.
AMERICA FUCK NO!
Old Mar 24, 2007 | 06:08 PM
civicized's Avatar
Is it possible this trans was modified for racing, the 5th gear removed and replaced with a handcuff type gadget?
Also, I would have someone shift the car into 5th while you are under it looking at the linkage and trans shift shaft movement to be sure it is pulling back, away from the trans toward the rear of the car. Be sure you see the trans shifter shaft move back and hear the trans clunking into gear.
Old Mar 26, 2007 | 05:15 AM
MAYMAY's Avatar
thanks guy
