integra door lock problems...
Old Mar 17, 2007 | 06:07 AM
thereturnofdark's Avatar
Obama made me Republican
Default integra door lock problems...
Hey went to unlock the door on my 94 integra rs with manual door locks and the key would not unlock the driver's side. Last night it began acting up, but i didn't pay it no mind. now this morning the door won't even unlock from the inside. It opens eventually but only after sitting there messing with it for about 5-10 minutes. any ideas what the problem might be and how i can fix it?
Old Mar 17, 2007 | 03:46 PM
TSX24L's Avatar
is it hard to turn the key in with the key in the door lock cylinder? I would take the door panel off and try unhooking the rod from the door lock cylinder and if its easy to manual unlock and lock then replace the lock cylinder, just rebuild it with new tumbers of the same numbers. I can help you with that on the side.
If its still hard to manually unlock and lock with the rod disconnected from the door lock cylinder then reconnect it to the door lock cylinder and disconnect it from the door handle and try it. You only have a few options here on manual door locks. On power door locks its either a door lock acuator or cylinder binding.
