compression test question
Old Mar 11, 2007 | 11:05 AM
dscivicdx's Avatar
TR Balla Donor Supreme
Default compression test question
so i did a compression test on my ls and the results were:
1: 195
2: 190
3: 190
4: 195
and got the same result on a second test that i did to comfirm the results.
so i was just double checking the numbers online and realized that i forgot to do the tests at w.o.t.
i did everything else the right way: motor was at op. temp, unpluged the coil and pulled the ecu/fi fuse.
should i bother re-doing the test? should i be worried that the numbers were so high with out the throttle plate being open?
thanks in advance.
Old Mar 11, 2007 | 11:35 AM
doeboy's Avatar
is it a stock LS motor? if so the numbers look good. im not sure about the W.O.T test, i think you should be fine.
1992 honda civic cx 2.0l
steeeeerrrrnss are gone
http://www.myspace.com/drew_doeboy
Nikon D50 w/ kit lens / Tamron 70-300mm DI LD macro AF/Nikkor 50mm 1.8f/Nikon SB-600 speed flash
Old Mar 11, 2007 | 11:44 AM
Alpha's Avatar
I would do it again at WOT. Only take you a little bit of time. The numbers will go up. Stock block?
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
Old Mar 11, 2007 | 12:48 PM
dscivicdx's Avatar
yeah, stock block. the only mods to the motor are arp headstuds. the head was just reconditioned and reinstalled with all honda parts. the motor has about 70-75k on it.
Old Mar 11, 2007 | 01:04 PM
TIM TIM TIM's Avatar
could be worse
numbers seem decent, as alpha said i would do WOT i noticed a differance when i did mine.
aim:because tim said
