Changed timing belt, car runs crappy.. help
Old Mar 6, 2007 | 03:13 PM
TIM TIM TIM's Avatar
could be worse
Default Changed timing belt, car runs crappy.. help
I tried changing the belt myself and apperantly got it wrong, it felt like it was a tooth off, VERY sluggish and hard to drive, so i pulled it back apart and had a mechanic i know (claims to be smart, worked for toyota for a while and now courtesy) had him do it, he SWEARS its right, hes sure.. no doubt and it still feels crappy, its not as bad as when i did it, but it feels a little slow, bigger deal is that its not smooth when reving it out, its jumpy and i KNOW its not right.. its on a 99 integra ls, I did change from aftermarket catback to a stock one at the same time, although i do not see how that could affect it..
thanks so much for any help.
aim:because tim said
Old Mar 6, 2007 | 04:19 PM
Alpha's Avatar
Sounds like the timing is off. If I am not down for the count this weekend (couple wisdom teeth) I can do it for you. I will let you know
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
Old Mar 6, 2007 | 04:23 PM
could be worse
what would you charge? feel free to pm..
Old Mar 6, 2007 | 04:45 PM
Gixxer's Avatar
Hide your daughters
Did you line up the cam timing with the crank timing??
They should all point TDC.
Old Mar 6, 2007 | 04:50 PM
could be worse
yeah, I am pretty sure i had it perfect, then had neighbore do it, SWORE its perfect and he knows all and put it together so i can only guess its right this time.. it starts fine, idles fine and cruises fine, just when accelerating its jumpy and feels slow, not that the car ISNT slow lol
Old Mar 6, 2007 | 05:29 PM
Gixxer's Avatar
Hide your daughters
Dizzy timing? Did you check with the timing gun?
Old Mar 6, 2007 | 05:32 PM
Alpha's Avatar
I'm going to have him come by this weekend. Will get it taken care of Tim
* IP E-Mail
* IP Face Book
* IP Web-Site
Old Mar 6, 2007 | 05:38 PM
could be worse
yep, alpha rocks although i dont really need to tell anyone that.
Old Mar 6, 2007 | 05:57 PM
rangcrx's Avatar
engine building &best
fire order right?best easiest way compression check see how close your numbers are
i love AUTOZONE
Old Mar 6, 2007 | 06:00 PM
could be worse
ill do one tomorrow! last i amonth or so ago and got a perfect 185 all across, crazy for a car with 100k IMO
also, why would the fire order be off? the plug wires are in the right spot, its not a missfire or anything, just a jumpy acceleration through the rpm range
