how the hell do u remove the hub!
and if all eles fails duct tape and a big ass hammer can fix anything
there are those of us who choose to fight and those of us who choose to stand on the fence and watch not wanting to get involved. but we all search for a small measure of inner peace but few of us ever find it
the wheel bearing has to be replaced when you remove the hub. They are sealed. Its alot easier to just press it off and then back on when everything is done. If you don't have a press just take the hub assembly or knuckle assembly off and take it to someone ; take it to someone to press it out for you then re-assembly everything. Take studs with you, you can't install new studs with the hub assembly installed to the knuckle. At least that i know of. I don't know of any short cuts for installing wheel studs.
+1 for removing the spindle, taking to shop, having new bearings and studs pressed in
just had it done on the coupe
if you can only race me in a straight line then whats the point
...91 SMF SCCA
...91 SMF SCCAhttp://www.flickr.com/photos/8341770@N07/5601083432/http://www.flickr.com/photos/8341770@N07/5601083432/ by http://www.flickr.com/people/8341770@N07/, on Flickr
– the late Tom Thrash SCCA Solo E Production
DJ,
If you get the studs, we can press out the hub bearing,
to press in the studs....and put it back if the bearing is good.
If it needs a new bearing, we can install that at the same time.
Bring me everything between the upper and lower ball joints
except the brake parts.
You can drop it off, and I can have it ready overnight,
depending on my schedule. pm me to set a day/time.-Bob
I still have the bearing press parts I made to do
that same job sometime back.
Well you have to replace the bearing regardless if its good or bad, trying to press that bearing racee back into the wheel bearing isn't good because it will not be properly sealed and dirt and water can enter into the bearing. It would be smart to just replace the bearing. I don't know maybe you know something I don't. I haven't heard anyone reusing the old bearing when having to remove the hub assembly for any reason.
Instead of doing all this, can you use maybe a diegrinder and cut off the old studs and fit the new ones in? or is the front side with backing plate in the way of doing this? I know some honda's you can get away with that, But i don't change out alot of wheel studs enough to know this.
For that spindle to come off you are either going to need to get right spindle puller or take the whole spindle assembly off and take it to get pressed out. Or you could get grinder and grind down part of the hud enough to knock out the broken wheel studs. I have done this before and it works. That is really all you can do, it is a bitch I know.
-BRAXTON
-BRAXTON
2012 Mustang GT 5.0 "COYOTE"..."TAMPA STOCK"
Jag,
While I can respect everyone's opinion, some hub bearings have the seals between the center, and the outer race. So removing the hub/bearing using the outer race does not affect the seal. Pressing the bearing in by using the outer race does not affect the seal. and some seals are removable and replaceable.
We both agree that a bad bearing should be replaced.-Bob
ill let u know bob. i dont have the money to buy a new bearing right now and i figure i might as well replace it now because if i dont, with my luck, it will need it done next month.
