Need help 89 hatchy Brakes!!
Old Mar 2, 2007 | 03:41 PM
Vcruz's Avatar
2 adjust the back brakes its with the brake adjuster witch is the part that sits in between the shoes u can adjust it with a screwdriver and how u adjust them is move the adjuster upwords and put the drum on and it should spin but should be a little tight and if u r unable 2 put the drum back on that means u adjusted them 2 much if u have any other questions call me 813-453-9876 i wk at a Honda shop....names Vic
Old Mar 2, 2007 | 03:44 PM
Vcruz's Avatar
Brake pedal going 2 the floor means either your master cylinder or brake booster is bad i would really have 2 look at it but the problem ur having seeems like thats what it is.....
Old Mar 2, 2007 | 03:50 PM
Thatguysstuff's Avatar
Hey its that guy!!
Well i had a brake boster go bad on me once. the pedal would not move,
I bled them some more today. more air came out and now the pedal is semi firm im going to adjust the back brakes tommorow after i get done doing the head gasket for the 3rd time.
If the car is not running and drive able tommorow im just going to sell it for what i have in it.
Old Mar 2, 2007 | 04:23 PM
Vcruz's Avatar
Well let me know bc i met buy it and the head gasket has probably gone bad three time bc everytime u take apart the head u should get the head resurfaced if u want it done the right way just some advice 2 at u....
Old Mar 2, 2007 | 05:04 PM
Hey its that guy!!
No the first 2 times i thought it was the gasket but the head was bad... it has a 95 dx head on it. now its from me not putting the gasket on right. So im gonna get all this done tommorow Hopefully all go's well.
Old Apr 2, 2014 | 02:51 PM
What order do you bleed the brakes?
What kind of car?
