eg rhd coversion
Old Mar 2, 2007 | 10:25 PM
Steve C.'s Avatar
hoollaa
4200? is that WITH motor?
Old Mar 3, 2007 | 07:46 AM
Durdan's Avatar
No Ants Drift Member
thats labor and clip. using his motor
RIP Tim. i miss you, buddy
Old Mar 3, 2007 | 09:26 PM
J-PEZ's Avatar
Professional Hussla
if you shop around you can get it as low as $2,000 but really not lower than that and over $3,000 is not worth it just total rip off
Old Mar 3, 2007 | 09:58 PM
Janky99's Avatar
Honda Guru
Guy in Miami does them, Very reputuble guy, I don't know if he is still doing them, his name is Powder, He's done most of the rhd hondas/acura's you would see on this board. -Ben
Old Mar 5, 2007 | 06:04 AM
Durdan's Avatar
then you should open up a shop and do it yourself bc obviously you know just how easy it is
Old Mar 5, 2007 | 06:40 AM
dippincrx's Avatar
save the s.o.h.c
im gonna have to agree. ive seen places out of state charging 1800 if you pull your engine. then do the wall and interior and brakes. you just drop your engine back in. and i see clips w/ engines for 2200 so 4200 is to much. ive i go thru w/ this ill be swapping it myself. i got a friend w/ a shop and with plenty of fabrications skills so swapping the wall for him will not be a issue. that was the only part i didnt feel confident doing
Old Mar 8, 2007 | 01:27 PM
  #17 (permalink)
doeboy's Avatar
4200 is a bit steep, but i do realize the labor factor. the conversion takes quite sometime, and when you have to pay someone for all the work they do. it does come out to be a large sum of money/hours.
i wouldn't try it yourself unless you have time and the know-how, you might find out that you've bitten off more than you can chew.
1992 honda civic cx 2.0l
steeeeerrrrnss are gone
http://www.myspace.com/drew_doeboy
Nikon D50 w/ kit lens / Tamron 70-300mm DI LD macro AF/Nikkor 50mm 1.8f/Nikon SB-600 speed flash
