tuning turbo
Old Feb 26, 2007 | 09:22 PM
Eluzzionz's Avatar
well wont a street tune be adequate..without worry of blowing ur motor until u can afford a dyno session. i understand you wont get the full potential through a street tune but if they dial in the a/f correctly u could red line ur motor without it blowing?? since my motor is almost done id really like to know..since i still have a few more things i need to buy before i can get it dyno tuned along with the break in period..
compared to a base map....where ur suppose to only be able to drive to the tuner..but not suggested to actually drive on a daily basis..???
Old Feb 26, 2007 | 10:00 PM
mtber's Avatar
Originally Posted by mtber
A tuner maybe able to dial in your air/fuel ratios by street tuning your car, however ignition timing is a little different. Some local so called "tuners" think they can read a few articles on the internet & look at other people's basemaps to learn how much timing to run. This works for the most part, but do they really know what they are doing ?
This is where experience & the importance of a dyno comes into the picture.
That is part of your answer.
Concerning starting up a fresh motor, I recommend having a tuner on hand or atleast a wideband oxygen sensor installed in the vehicle to ensure that the rings are not being washed out by tons of fuel.
Old Feb 27, 2007 | 01:06 PM
flaco0018's Avatar
Thumbs up
+1
It amazes me how people spend a few thousand dollars building their motor & buying a turbo kit but they hesistate to spend several hundred dollars when its time to spend money on tuning.
+1^
10.6@136 k20
ALPHA TUNING For all of your tuning needs 7275051423 Induction Performance
BUILT BY KJ
