how do i wire vtec engine into non vtec car
Old Feb 28, 2007 | 02:51 PM
CRXcominup's Avatar
ive already got y8 im , y8 dizzy, i just need to know whats the easiest way to convert to the im , dizzy and i guess i know how to convert the ecu and how to hook up the solenoid the right way thank you
Old Mar 2, 2007 | 03:27 PM
brax90si's Avatar
I have done this before and used a OBD-0 Pr3 ecu. It is a JDM B16a ecu. It will require a KNOCK SENSOR, but other than that it will work without converting to OBD-1. Actually it worked great. I used a D16z6 in a 1990 civic si, I was already MPFI. But after you convert to MPFI you will be fine.
Old Mar 2, 2007 | 03:35 PM
brax90si's Avatar
The Effin Guide to MPFI swaps
This is site to help you through DPFI-MPFI conversion.
-Brax
