changing water pump and timing belt
Old Feb 19, 2007 | 06:12 AM
TIM TIM TIM's Avatar
could be worse
Default changing water pump and timing belt
Looks litk its about that time for me, Im going to try to pull it all apart, hopefully put the water pump on and then let my neighbore do the timing belt since i have no clue how.. anyone have any tips or anything with getting it apart
aim:because tim said
Old Feb 19, 2007 | 09:03 AM
99B16Si's Avatar
have sure you have a good airgun or crank pulley bar to get the crank pulley bolt out. also have the motor at TDC when you take the old belt off, saves u a possible small headache when puting the new one on.
Old Feb 19, 2007 | 09:22 AM
could be worse
thanks, i have an airgun so that should be fine... anyone know of any write ups or anything on doing this job?
Old Feb 19, 2007 | 10:00 AM
99B16Si's Avatar
Honda, Acura Tech Website, tutorials, tuning and HOW-TO's. Drag racing, street racing, road racing - C-speedracing.com
Old Feb 19, 2007 | 10:49 AM
My Honda Is Slow's Avatar
No really,....it is
haha good luck on that crank pulley bolt!! i have used 1 inch impacts before to get them off before but that should be your biggest problem i think
Originally Posted by Cold_Beer
JDM is gay, speed holes rock. /thread
35 mpg...... with the ac on bitches!
I got V-TECH AND HEADERS!
Old Feb 20, 2007 | 04:58 AM
skunk2racing97's Avatar
UF Mech/Aero Eng
hahahaahaha you took my pic of my guns in my house, thats awesome...
as for this post, do a search. ive posted timing belt/water pump Helms pics on here numerous times, you should be able to find em pretty easy.
Old Feb 20, 2007 | 08:00 AM
could be worse
thanks guys
Old Feb 24, 2007 | 10:09 AM
could be worse
im in the middle of this and the directions that link has tells how to get the alt and a/c belt off but i have a 3rd belt there, im guessing power stearing? how the hell do i get it off.. it appears there is a tentioner there, the belt goes from crank pully, tentioner(im guessing) and then towards the front of the car/bottom next to the header.. any help would be greatly appreciated
Old Feb 24, 2007 | 11:59 AM
UF Mech/Aero Eng
outermost belt goes to the PS pump, up high off the front of the valve cover.
-loosen the two bolts that hold the PS pump on, then lower it enough to get the belt off.
second one in is A/C, thats the lower front (by the header)
-loosen the bolt on the tensioner arm (just a little bit)
-loosen the tensioning bolt, and the tensioner should rotate down so u can pull the belt off.
third in is the alternator, back of the block.
-loosen the top bolt and you can rotate the alternator toward the block so u can remove the belt.
installation is the reverse of removal.
g/l
Old Feb 24, 2007 | 12:05 PM
could be worse
well i got all of that figured out, got the water pump changed. now putting the new timing belt on, one of the cam gears is moved from the up arrow pointing strait, it looks to be 1 tooth off from the other, when i try to move it back its like there is a shitload of pressure on it, i can move it but it goes right back to where it was... wtf do i do??
