suggested comp ratio
Old Jan 29, 2007 | 08:04 PM
  #21 (permalink)
mtber's Avatar
Originally Posted by Eluzzionz
ok enough said..mtber t4eg kj and everyone else..ty for ur info and ill go ahead and use 9:1...other then that..the 81.5mm bore on stock ls sleeves...and info on that ? like what kind of barrier i should have..etc..thx again
As we have seen, stock sleeves can take 500+ whp with proper tuning, however the question is, how long will the sleeves hold up to the abuse.
If you have concerns that you will eventually want enough power to put your sleeves at risk, simply sleeve the motor to 84mm and buy 84mm 9.0:1 pistons.
Old Jan 29, 2007 | 08:42 PM
  #22 (permalink)
Eluzzionz's Avatar
like mentioned 350whp will be plenty in a crx imo..anything else would be useless on the street without major mods that i wont be able to afford anytime soon...i plan to obtain 350whp..then work on the interior/exterior of the car..i just want to see if u guys think 350whp on 81.5mm sleeves will hold without problems...for atleast a yr..
Old Jan 30, 2007 | 03:24 AM
  #23 (permalink)
60-1EK's Avatar
Engineer at the source
Originally Posted by B20.eg
Hey i used arias 10.1:1 on my 81.5mm gsr and made 340whp @13 psi on 93, with a daily driver tune by "the king" john vega. 10:1 is better for a street car because of the simple fact that off boost you will have more throttle response and pickup. you won't be riding at 10+ boost all the time, so why not have some good power in the mean time. 8.5 is for high hp race cars(30psi). 9.1-9.5 is better, but if all you want is 340-380 whp, go with the higher comp. thats from my personal expirience.
You were also running a 60-1 turbo. That is why you made the decent power at 13psi. Race cars typically run race gas and therefore enable you to run higher compression. 8.5:1 compression on a race car would be stupid unless you just want to run a ton of boost on pump gas.
JESUS SAVES
9.69@151 Street Car
JKOBD
Old Jan 30, 2007 | 09:21 AM
  #24 (permalink)
T4eg's Avatar
81.5 would be fine for 350whp just maintain the car and it will last forever. And also IM agreeing with 60-1EK 8.5:1 compression?? its not a dsm...my current setup is 9.5:1@30lbs
Old Jan 30, 2007 | 09:30 AM
  #25 (permalink)
Eluzzionz's Avatar
i dont know my exact trim of my turbo...i know its a t3/t4 turbonetics turbo...just not sure how to figure out the trim...any help?
Old Jan 30, 2007 | 04:59 PM
  #26 (permalink)
lzylst's Avatar
also depending which vtec head your using raises or lowers the compression approximately .2
b16 (pre3) casting will lower the compression if your trying to figure the gsr pistons those numbers are being based on a gsr head. Hope that made sense to you Eluzzionz.
Vance @ 863-604-2139 for any questions
Old Jan 30, 2007 | 05:08 PM
  #27 (permalink)
Eluzzionz's Avatar
yea i understand that..like mentioned though with the ls bottom end and b16 head with ur pistons itd be at 9.77 from what i calculated...since i cant find a FOR SURE -cc i went with -2cc since thats what it takes to make a gsr with 81.5 bore to 9.8:1 thx..
