Car Feels A Bit Sluggish Taking Off
Old Jan 22, 2007 | 05:56 AM
willito4u's Avatar
Default Car Feels A Bit Sluggish Taking Off
Ok Well I Have A 00 Civic Si I Had To Replace The Motor So I Put In A B16a Sirii In It Everything Seems Fine. However It Feels A Little Sluggish Taking Off On Topend Its Running Great.
The Motor Only Has Regular Boltons And I Have A Stage1 Act Clutch Kit In . Does Some One Know What Might Be The Cause Of This Slow Take Off?
Old Jan 22, 2007 | 06:43 AM
skunk2racing97's Avatar
UF Mech/Aero Eng
vacuum lines incorrect, IACV that isnt functioning properly, poor ignition timing, low compression....
id suggest you start with the basics... because its a used motor, and im assuming you havent opening it up, check the compression first, to make sure your headgasket/rings/valves seats are good, then time the distributor with a timing light, so its spot on, then get into the little stuff...
Old Jan 22, 2007 | 07:01 AM
willito4u's Avatar
ok well the mechanic supposebly checked that stuff. do you think i should take it to a tuner instead?????
Old Jan 22, 2007 | 07:06 AM
UpInYa's Avatar
Marijuana my anti-drug
that cant ever hurt anything.i would if i were you
