a/c belt on ls/b18
Old Jan 14, 2007 | 02:14 PM
Anthony R's Avatar
SAL-T
Default a/c belt on ls/b18
new to my acura well hondas for that matter. got a question i want to know how i get the a/c to crank belt off. i got it off the pulleys but there is like a bracket that runs from the a/c compressor across to the frame. does that come off?? lmk. any help would be much appreciated. thanks
Matthew "RudeBoy" Nugent 2/03/88-04/01/09
Old Jan 14, 2007 | 03:28 PM
zedron's Avatar
Yes. It is a front motor mount. You need to remove the 2 bolts that connect it to the frame and then slip the belt around it. Vise-Versa for installation.
B20 Non-Vtec Turbo: 275whp/234wtq @ 8 psi 2/10/2007
LS/Vtec Turbo: ???whp/???wtq @ ? psi (Secret )
Tuned by John Vega @ Phearable.net
Old Jan 14, 2007 | 04:14 PM
Anthony R's Avatar
SAL-T
ok thanks will do it 2morrow,
Old Jan 14, 2007 | 05:23 PM
99B16Si's Avatar
u need to remove the 2 14mm bolts thats hold the lower mount to the frame. then you need 2 loosen the upper driverside mount so the motor lowers an inch or 2, then youll be able to slip the belt around the lower mount
