h22a w/ s2000 trans?
no it isnt... impractical, yes... but you COULD make it work... it would have to be a RWD or you would have to run a funky ass Lisa Kubo Saturn setup to make it FWD... anyway, it would cost WAY more than it would be worth... for that much shit just swap an S2000 swap (whole thing) in a lude... it would be less work to do that...
actually it will NOT work. The h22a spins the opposite direction as the s2k engine. you would have 6 reverse gears and 1 foward gear. Now a k series engine will be able to mount to a s2k tranny with an adapter plate.
what about all the stuff that would crunch the firewall and the motormount issue.
if you have a s2k isn't a h22 a step backwards from the original engine?
[fortune cookie @ Ling's garden]
