turbo ?
Old Jan 4, 2007 | 07:26 PM
mtber's Avatar
Originally Posted by Eluzzionz
i have obd0 dizzy...
You can't run an obd0 distributor on a obd1 ecu.
You must run an obd1 or obd2 distributor with an obd1 ecu.
Old Jan 4, 2007 | 07:32 PM
Eluzzionz's Avatar
thats what i thought..thats why i said i need a obd1 dist...ty..do i need anything else to convert...ecu dist conversion harness?...and i think a 4 wire o2 sensor????
Old Jan 4, 2007 | 09:56 PM
mtber's Avatar
You need an obd0 to obd1 conversion harness.
You will need an obd0 to obd1 or obd0 to obd2 distributor conversion harness depending on what distributor you use.
You won't need a o2 sensor because o2 feedback can be disabled.
Old Jan 5, 2007 | 08:04 AM
Eluzzionz's Avatar
ok thanks alot..
Old Jan 5, 2007 | 01:29 PM
caRRRR's Avatar
i have the full turbo kit...just need new piping and dp...i guess ill get a new map sensor cuz i plan to do 15-16lbs..im gettin a chipped p28 most likely chrome tuning...
i was tired. i guess i didn't read it through...
Old Jan 8, 2007 | 12:25 AM
juiced2ndgenteg's Avatar
completely plug and play.
