Halo Light assembly
Old Jan 7, 2007 | 03:04 PM
Pepsicola1489's Avatar
Control_x3
Default Halo Light assembly
Does anyone know how to wire up Halos
PM please and let me know how to do it. I tried the way my buddy told me how to do it and it didn't work out to well.
Old Jan 7, 2007 | 05:22 PM
Obviousreasons's Avatar
Welcome to Candy Mountain
There should be 2 wires coming from the halos. One goes to ground, the other goes to 12 volts. Just check and make sure you get the polarity correct, most cases they use LED's to light the halos. And LED's can not be hooked up backwards, if you do hook them up backwards they will burn out.
Good luck.
Need your Honda/Acura tuned? Ecu Chipped?
Http://www.Phearable.net
Need some Stereo/Security/Video Work Done? Almost Anything 12 Volt I can do. 12 Years Experience. Send a PM For Inquiries.....
Old Jan 8, 2007 | 12:24 AM
+1 on the polarity to light them.
Generally Diodes block current in one direction.
An LED is a Light Emitting Diode.
A second way to find the proper wiring, is to phone/email the
company and ask for another diagram.-Bob
Old Jan 8, 2007 | 12:27 AM
This from eluzzionz:
im not sure exactly how urs are..but..on my crx...the lights for the halos..u tapped in to the corner lights...just cut wire and use connectors to crimp them...
-Bob
