need help now please!!!!!!
ok i got a ef hatch with a obd1 motor,the car has been running great,well me and my buddy stopped by sonic drive thru and it was all fine,when we went to pull off the car just died,now when you turn the key on the main relay fuel pump and iacv clicks and acts weird,the car will turn over and gets fire and fuel but will not start the relay just clicks and clicks,can someone help me with this?
not too sure with the info given but maybe a broken timing belt.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
timing belt is fine,the car wouldnt get fire if the timing belt was broke,the starter does not click it works perfect it turns the engine over,the lights radio dash etc etc all works,the main relay just clicks,so i replaced it with a new one and it still clicks,the main relay will stop clicking when removing the plug from the iacv,but it just stops the clicking it still turns over,i have no clue i am lost,it seems to me that the car will fire up.i checked to see if it was getting pressure to the fuel rail and it was so i am assuming that it is getting fuel.
+1
and also is the fact that it has fuel pressure, the only reason you're assuming it has fuel or did you make sure the injectors are firing??????
check the injs. with a noid light if you didnt already!
NO EXCUSES for my lil FWD! Cmon RWD's n AWD's, lets DIG!
STEISS RACING all the way
HONDA ENGINES from oem to EXTREEM
www.myspace.com/streetracin_cwby
http://www.facebook.com/#!/profile.php?id=1433200141
if the car was runnin then just died, and you check spark, fuel, and you are getting Air. then its probely just a fues or somthing burned out. this probely didnt help but just wanted to put my 02 cent in.. G/L on your car Bro.
