mini me questions
Old Jan 1, 2007 | 09:09 AM
HondaHouse's Avatar
IS AT THE DEALERSHIP NOW
even if u decide to stay obd0, u can run a b16 pr3 ecu and get it tuned...no prob..thats what we did on wifes crx, none of that rpm activated switch shit...u use that u run lean when vtec engages...not good
Mike @ 239-851-3234...anything pertaining to HONDAS
Originally Posted by Jordan T
sounds like you have a problem, your car is a mitsubishi, try replacing it.
Old Jan 1, 2007 | 09:21 AM
unique intensions's Avatar
Yeah it will drop right in its a d series, and for the rebuild if the block was bad like smokeing or the bearings are bad or you where burning oil stuff that the motor was bad to start with yeah rebuild the bottom end. Just look at this way all dseries are interchangable so goes for bseries as well. But if the block was good and the head is to just put them together nothing has to change. It will fall in fine no mount has to be changed and when you put the head on the block I would use the y8 head gasket with build. But overall if block is good dont do anything just put it together and you'll be fine.
Old Jan 1, 2007 | 09:24 AM
Yeah I know it causes it to run lean but for know it was just something to get him running with what he had. But just giveing him ideas in what he could do.
Old Jan 1, 2007 | 09:31 AM
HondaHouse's Avatar
10-4 completely understood, but with the money that we would spend on the rpm switch, he could use that to buy the wires and pins to do it right
Old Jan 1, 2007 | 09:56 AM
Yeah I know, I'm not saying to get one just makeing sure his vtak is working. But really I think he should go obd1 and run the p28. But like you said he needs wires and pins for the mpfi conversion. But he's looking for help and ways and the z6 on the y8 head would be best insted of the 1.5 mini me. But overall if block is good and head is good put them together do dpfi to mpfi get the conversion harness for obd0 to obd1 wire it up and he will be running. But if he would like to stay obd0 he could use pr3 tune it up for single cam use and he'll be rolling. But its all up to him and how much money he is willing to spend.
Old Jan 1, 2007 | 10:29 AM
Skee's Avatar
im gunna be safe and rebuild th d16 instead f just dropin in i dont want to pull it back out lol i wanna n/a buid so im a find some high compression pistons and i been lookin on d-series.org got some good ideas
o ya on my motor the top of it is al scratch can this be fixed ((sratched where the block and the head meet not badbut like it was moved on the ground few scrapes can i get this machined?
Old Jan 1, 2007 | 11:30 AM
  #17 (permalink)
I would think so, send it to get resurficed and clean up. Going HC is a good way for a dseries or you could run nitrous. But let us know how your build is going and if you need more help, where here to help you through. Any question just ask and with or best knowledge we could help you led to a good motor build and not have any problems with it.
Old Jan 1, 2007 | 11:54 AM
  #18 (permalink)
Skee's Avatar
does anyon know where i can get head work done like get new springs and valves that wont brake the bannk and a place to get the motor resurficed?
Old Jan 1, 2007 | 12:23 PM
  #19 (permalink)
SmokinS13SR20's Avatar
That ginger...
Since you want to do a N/A build, machining the head/block surface would be good since it will bring up your compression a bit.
Old Jan 1, 2007 | 02:16 PM
  #20 (permalink)
Have you tries ebay.
