98 gsr motor
Old Dec 24, 2006 | 06:53 AM
streetlegends's Avatar
STREETLEGENDS!
Default 98 gsr motor
98 gsr motor i push in the clutch & the car still wont go in gear is that the throw out bearing or anything else lmk asap this is my only means of transpertaion
Old Dec 24, 2006 | 08:04 AM
skunk2racing97's Avatar
UF Mech/Aero Eng
1) check/flush clutch fluid. if it is/was low, you may have bubbles, which wont activate the slave cylinder enough to disengage the clutch
2) check for proper master/slave cylinder operation. if you have old parts, and a stiffer pressure plate, these parts may fail.
3) possibly a busted pivot bearing, but more likely 1 and/or 2
4) broken pressure plate teeth. only usually happens with REALLY high pressure loads tho, so unless you are running a rediculous PP, check 1 and 2
Old Dec 24, 2006 | 09:30 AM
Pyroproblem's Avatar
Porsche Tech/Honda Tech
Check the slave cylinder for movement so you can verify proper hydraulic operation. If its good, your gonna have to pull the tranny for further diagnosis...
Good luck!
(Im betting its your clutch master cylinder personally)
Now residing in Atlanta.....
