Valve cover gasket question
Old Dec 3, 2006 | 01:00 PM
hondachris1994's Avatar
hatchback1994
Originally Posted by CubanYoshi
REPPED!
no problem
Old Dec 3, 2006 | 01:38 PM
wb_map3's Avatar
yes you can take the vc off without replaceing the gasket but be carefull and no you dont need to pull the diizy to replace the cam seal im talking about its that little black circle on the left when the valve cover is off just pop it up and put a new 1 in
Old Dec 3, 2006 | 02:59 PM
CubanYoshi's Avatar
You can't handle it
Well the thing is the cam plug (seal) is good but I am almost 100% sure that the distributor o-ring is bad. In the How-to above it says to not turn the fins, is he referring to the little notches on the dist. that goes into the camshaft? Would it be detrimental to twist or turn that after removal?
On another note, is there any place locally that sell this kind of cam seals? eBay Motors: GOLDEN EAGLE CAM SEAL TRIPLE O-RING SEAL DOHC VTEC (item 230057104414 end time Dec-05-06 09:01:36 PST)
THE CIVIC 2004-2009
Old Dec 3, 2006 | 03:15 PM
hatchback1994
the way u pull th e dizzy is the way u put it back in easy as that, pull dizzy off put new ring on, put dizzy back on and line it back up, tighten bolts back up and then your done, simple as that
Old Dec 7, 2006 | 02:26 PM
Before I remove a dizzy, I remove the cap and mark the position of the rotor against the housing.
I also mark the position of the dizzy housing against the head.
That way when I pull the dizzy horizontally, I can replace the seal/o-ring
lube it, and return the dizzy back into the head, rotate the housing until
the housing marks line up, and the rotor marks should line up, too.
If the rotor marks DON'T line up, I pull it back out JUST ENOUGH
to rotate the rotor (almost never more than 1 tooth off), and reinsert the dizzy. Both marks should now line up.....or I remove, rotate slightly and re-insert the dizzy until they do line up.
The absolute cheapest dizzy/o-ring seals come from NAPA.
I carry my dizzy to NAPA, ask them to get a dizzy from the parts shelf that duplicates mine, they will measure the size of their O-ring, and sell me one the same size........cooperative guys! If I try to buy it as a "seal" it costs more.
Good luck, and let us know how things go.-Bob
Old Dec 7, 2006 | 02:33 PM
elwrestler03's Avatar
MrB18crx
good advice rep given
wb_map3
ta b real witcha i actually 1 a spellin b as a jit n i alwayz got 100 percent on all my spellin test even got da bonus wrds rite and got an a in english 1-4 in high skool so lets leave the post ta buying and selling parts iight
