B18A1 into dc2.
Old Nov 29, 2006 | 12:40 PM
hkshaitian's Avatar
Default B18A1 into dc2.
I just wanted to kno if this block would work in a dc2? Thanks
Old Nov 29, 2006 | 01:55 PM
skunk2racing97's Avatar
UF Mech/Aero Eng
yep. direct replacement for a B18B.
Old Nov 29, 2006 | 03:03 PM
wb_map3's Avatar
yea they are basically the same thing..if your replacing it to make it faster its the same but if u blew your other 1 and just want to replace it then yea it'll wrk direct bolt up
Old Nov 29, 2006 | 03:17 PM
hkshaitian's Avatar
Thanks for the info guys.
Old Nov 29, 2006 | 03:46 PM
hkshaitian's Avatar
Wat about a b18a1 head can i use that also? Do i have to swap out disty and injectors?
Old Nov 29, 2006 | 07:29 PM
Steve C.'s Avatar
hoollaa
a b18a1 CAME in DC2!
Old Nov 29, 2006 | 07:45 PM
wb_map3's Avatar
no a b18a didnt come in it a b18b came in it
Old Nov 30, 2006 | 01:47 AM
freakasis's Avatar
sorry guys your all wrong....the dc2 came with the b18c1 or the b18c5....you guys are thinking of the dc4.....
now if you realy meant dc2 than the blocks are inerchangable....not the same though you will need a tune. and the b18a1 head will not go onto your block
if you meant dc4 than yes the blocks are interchangable and you will not need a tune, and the b18a1 head will be fine just use the dizzy and manifold that are in your car to make it easier.
Old Nov 30, 2006 | 03:33 AM
K20A2's Avatar
OH LAWD JESUS ITS A FIRE!
I thought the a1 came in the gs?
Old Nov 30, 2006 | 03:50 AM
robunicu's Avatar
Nicolai
90-93 integra rs/ls/gs came with b18a1
94-01 integra ls/gs came with b18b
90-93 integra gsr came with b17
94-01 integra gsr came with b18c1
type r came with b18c5
this should clarify everything.
the b18a block is pretty much the same block as the b18b and u can interchange them.
PBM fender roller for rent!!
