leaking tranny
Old Oct 30, 2006 | 06:25 PM
Old Renegade's Avatar
Cool Runnings
Originally Posted by skunk2racing97
Honda Automotive Parts
actually, as i recall, and according to the honda parts catalog (items # 22 and 23) there are washers on both the fill and drain plugs.
the OEM bolt, with the washer, torqued to spec, should NOT LEAK at all. if you need to use gasket sealer, you either need a new washer, or your bolt is not tight enough.
thanks but from the pictures it looks like i undid #14 and #15. this is a b series tranny iof this will help any. i always tighten my stuff real good but will look into re-tightening and or if i need a new bolt thanks. what about the loctite and the honda bond idea?
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
Old Oct 30, 2006 | 06:27 PM
skunk2racing97's Avatar
UF Mech/Aero Eng
its the same with whatever bolts you undid. honda doesnt seal anything other than the trans housing/clutch housing from the factory, so torque specs should do it.
but if puch comes to shove, then get some gasket maker/hondabond and put some on the threads. it should work just fine.
and just so you know, that pic is a B16 S4C trans.
Old Oct 31, 2006 | 12:03 AM
Cool Runnings
will look into re-tightening it, but i will also look into getting some honda bond and put it on there one time so i will have some extra security. thanks for the ifo. it is much appreciated.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
Old Oct 31, 2006 | 10:55 AM
Hater's Avatar
Free base cocaine
use a torque wrench set it to the proper settings tighten, done. you proably just hand tightend and it's seeping out.
Old Oct 31, 2006 | 11:18 AM
Cool Runnings
will check that out. did it with my hand but i really put a effort into tightening stuff. will get the specs hondabond and go from there.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
