who on here is turbo w/ >10:1 compression?
Old Oct 27, 2006 | 07:16 PM
B20.eg's Avatar
i think its they way i'm gonna go robert. BUT, i will be using the info you provided me with about the gasket and tuning later on towards spring break next year to do it since i can't be without my car for a week and go to college and work. I think this is gonna turn out very well! now if i can just get Hermsfab to finish the manifold i paid for 3 moths ago, i'd be all set!
Old Oct 27, 2006 | 08:09 PM
mtber's Avatar
Originally Posted by Alpha
If your final static compression yields 10:1 you will be fine. I prefer 9:1 on pump gas street cars but 10:1 will be fine. Especially the pistons being forged
+1
Old Oct 27, 2006 | 09:15 PM
Deuche's Avatar
will stock rods hold that much HP ? i know the weak point on the Cast pistons are the skirts but ive never really looked into OEM rods as ive never used them in a build up. If anything use ARP rod bolts I know the LS has 1mm smaller rob bolts than the GSR ITR i think they are 8mm. if im not mistaken.
Old Oct 27, 2006 | 09:27 PM
mtber's Avatar
They will be fine at 300whp but I is always a good idea to upgrade
Old Oct 28, 2006 | 04:48 AM
freakasis's Avatar
pretty sure
ls=8mm
gs/type-r=9mm
Old Oct 28, 2006 | 07:06 AM
B20.eg's Avatar
cool, my gsr rods and bolts will be just fine then
Old Oct 28, 2006 | 07:41 AM
  #17 (permalink)
mtber's Avatar
Like I said before, do your self a favor and build the motor with pistons/rods the first time so you don't have to tear it apart down the road.
300 whp is a good power range for a street car, but you will eventually want to make more power just because you can. You will then be limited by your rods
Old Oct 28, 2006 | 07:57 AM
  #18 (permalink)
Alpha's Avatar
I agree. You will want more than 300whp once it's done. Unless you want to see how far you can push stock rods I have seen them fail at 500whp. I have seen them fail at 300whp too
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
Old Oct 28, 2006 | 07:59 AM
  #19 (permalink)
B20.eg's Avatar
well, the motor has been built and being driven for over a month and a half now, so i'm prolly not gonna pull it out to re-do anything. and i made over 500 hp in my RX-7, so i know the high number feeling, but i'm not going for that. the civic is going to have good strong power, but i also have ac and all the comforts too. i'm not going for king of the streets, just a fun turbo daily driver.
