starter problem
Old Sep 23, 2006 | 03:16 PM
LATINO HONDA's Avatar
BALLER
Default starter problem
it wont start so i had to push start it and it started so i got one wire and touch the starter with both it started so i bridge it from the top pedal and it starts with out pushing the clutch so i thought it was the neutral safety switch and i change it with a new one but it still didnt work so it is still bridge so some one please help me
Old Sep 23, 2006 | 06:13 PM
hondachris1994's Avatar
hatchback1994
just leave the wire jumped at the top of the clutch pedal, Ive had mine like that for a while now doesnt hurt anything unless u dont push the clutch in and try to start it in gear then u might hit somethin
Old Sep 24, 2006 | 08:48 PM
Have you checked to see if the switch passes current when the clutch is pushed in?
Is the switch adjustable to where it *will* pass current?-Bob
Old Sep 24, 2006 | 09:39 PM
BALLER
thanks guys
Old Sep 25, 2006 | 07:51 AM
DD.'s Avatar
DD.
Administrator
Yea my switch doesnt work either. just run the wires to a switch from autozone and mount it under your dash or something. pm me for deeper instuctions if you need.
Old Sep 25, 2006 | 08:56 AM
Sabotage's Avatar
slash
yeah, have fun. i just went thru that. i was having an intermittent starter problem. i thought it was the switch bc i had adjusted it and that bought me a couple months. that and i took my starter out when i did that and it bench tested fine. then yesterday my car wouldnt start. i put in a new switch hoping thats all it was and it still wouldnt start so then i put in a new starter. everythings fine now. stupid intermittent starter.
meows meows
TRick Squad Member #3
VicPrez of IttyBittyTittyCommittee
Old Mar 22, 2014 | 09:17 PM
car starter discussion
