squeak when i turn left
i have a 95 gsr i put a new ball joint in and it now makes a squeak noise on the side i put it on when i turn left or go over a bump but mainly turning left what is it
Dust shield might be touching the disc=noise. Thin metal; easy to bend it back. Jack it up under lower control arm and rotate the wheel to sound test it.
Is any paint worn off the new ball joint?
Is the control arm with the new bj getting close to anything under the
fender? Check also to see if the tire sidewall might be polishing any metal
under the car, including the sway bar, ball joint, and the inner fender.-Bob
