spits and sputers
Old Sep 20, 2006 | 12:41 PM
Skee's Avatar
ya its gone and i cant find the wire that should be plugedin there i ahve a sensor in there but no wires
Old Sep 20, 2006 | 12:46 PM
Skee's Avatar
this is probbly what wrong with it? if so how to fix lol cause i dont see a plug even a wire close to heading to that area
Old Sep 20, 2006 | 12:47 PM
integraman89's Avatar
lost u already???
ok... that may be your problem... not having an oxygen sensor hooked up can cause you car to run wierd bogging down and such... it may be in your best interest to have someone locate the original wires to wire it back up the original way...
Old Sep 20, 2006 | 12:49 PM
Skee's Avatar
i have a cut wire i found im a take a pic of it real quick
lost u already???
also... with that unplugged it will be hard to get a proper reading of the thrown engine codes... so you may wanna locate the wires, hook it back up, then take ur car to autozone to get that free check engine light test
Old Sep 20, 2006 | 12:51 PM
chi town brat's Avatar
! Ne shab'rud'ni !
91 ef
Stock ECU? OBD0. Turn the key on, then pull down the carpet on the passenger side and look at your ECU, it has a flashing red led light. They do single blinks. Count the number of blinks you see. When you see a long pause, wait and count the number of blinks again. If it is the same number you are only flashing one code, if you have a different number of blinks after the long pause then you have a second code. Repeat until the same number of blinks occur after each long pause.
You can find the ECU codes online with a search.
Hope this helps.
Old Sep 20, 2006 | 12:56 PM
  #17 (permalink)
Skee's Avatar
Old Sep 20, 2006 | 12:58 PM
  #18 (permalink)
lost u already???
so you found the wires going to the ecu... now you need to locate the sensor on the exhaust to wire it back up. looks like some one ripped it off by accident..
Old Sep 20, 2006 | 01:00 PM
  #19 (permalink)
lost u already???
by the looks of the length of wires you have... the sensor is on the header/manifold... should be on the lower left side if ur facing the motor
  #20 (permalink)
Skee's Avatar
my sensor has 4 wires on it and the wires are all cut to short i probbly need a new sensor
and on the eco she blinks 17 times
