clutch/tranny f-d up??
well if you are d series, i would replace the tranny if i were going to replace my throw out bearing since the trannys are a dime a dozen.... but in order to change the throw out bearing you have to take the tranny off, and when you do that you might as well change the clutch blah blah blah ect. So really think about how much you want to do and how much you have to work with. I have never heard a throw out bearing just on deceleration
Alarm Crazy!
|| 1994 Honda del Sol vtec || B16a2 || 2 engines in garage one in car
w00t status ||
-John
Aim: le lead
Cell: (813)843-8523
Alarm Crazy!
w00t status ||
-John
Aim: le lead
Cell: (813)843-8523
and to change the throwout bearing... u would only need to unbolt the bolts holding the tranny to the motor pop out the axles and slide the tranny away from the motor a few inches... leaving all the mounts inplace, u should be able to get to the throwout bearing like that, i have change many clutches in hondas and found that i could do it this way... rather taking the whole tranny out... i guess in order to do it this way, you would have to have experience of doing it this way
thanks for all the input guy, i guess im gonna be spending my weekend checking all this stuff. anything else anyone else had to say will also be appriciated! thanks
She may not look like much but she's got it where it counts....I've made a few special modifications myself
did you try lucus oil?
Alarm Crazy!
w00t status ||
-John
Aim: le lead
Cell: (813)843-8523
Alarm Crazy!
w00t status ||
-John
Aim: le lead
Cell: (813)843-8523
this is my first time doing any clutch work. how difficult is pulling the tranny if i dont have a lift. ive got a bottle jack some ramps some jack stands and a floor jack. is this a drive way job or do i need to take it to some one to have them do it. im pretty mechanically inclined but should i just bring it to some one??
nah its easy, all you need is a jack and jack stands, and if its a d series you don't even need the jack, you can just lift it, they have a write up on how to do it on honda tech, thats what i used the first time i did my clutch, it's pretty easy but there is a lot to it so don't be scared but don't be suprised if it takes you 5-8 hours your first try
Alarm Crazy!
w00t status ||
-John
Aim: le lead
Cell: (813)843-8523
Alarm Crazy!
w00t status ||
-John
Aim: le lead
Cell: (813)843-8523
yeah i have a d-series. 5-8 hours huh? with my luck it will probably take 2 days!! ill have to look at it and see. thanks guys!!
