car boggs from 1.5k to 3k when accelerating.
Like the title says. Im throwing no CELS. Its a crx si converted to obd1 with a z6 in it. Only thing thtas changed is i put a 4-1 header on it and a new bosh o2 sensor.
Another problem it has is that if im cruising along then put it in neurtal when comeing to a stop, the rpms will drop to 0 and either car will shut off or rpms will shoot back up to idle and then idle shitty.
Any ideas?
LMK,
Thanks in advanced
Mondo
Any ideas?
LMK,
Thanks in advanced
Mondo
i dont know what he is talking about. if the parts place you bought it from said it was OEM compatible, FOR THE ECU you are using, then you should be fine.
no CELs and it was fine before you switched the header/o2 sensor? and all you did was touch the header/o2 sensor?
Check your dizzy can be taking a crap soon cuase mines was doing that till it went out completly check your Rotor button cap etc you know basic dizzy components
TampaRacing's DEAD!!
yea i was thinking about doin that. I hope its not the dizzy since i just droped the motor in. I havent drivin more then 3k miles on it yet. And i bought the dizzy brand new from Import Auto in Lakeland..i think thats the name of the place.
I have had a problem with 3 bosch 02 sensors I have put on hondas with hesitation. I bought the $40 "factory" replacement ones. On my own car I tried one and it worked for about 3 days. I went out and bought a denso 02 sensor and never had a problem again. try unplugging your 02 sensor and driving on it. some of the hesitation should go away. if it does then that is your problem.
(813) 523-0168 Sid
(813) 476-5383 Justin
(813) 523-0168 Sid
hmmm... well then i owe SXECROW an apology. i had no idea that there was a common problem with Bosch sensors. i have one and it works fine. maybe you should try another one.
there must be something else going on there....
No problem. We're all here to learn stuff
I steer clear from Bosch. Denso is pretty good but you can't beat the OEM part.
