fuel filter
Old Sep 11, 2006 | 08:10 PM
custom240sx's Avatar
DC Crew Member #1
Default fuel filter
I was just wondering if there is a different higher flowing fuel filter that can be used on 1990 acura ls engines? I know the nissan guys with the 240s use the 300zx filter on them for higher flow.
Old Sep 12, 2006 | 08:47 AM
mtber's Avatar
You dont need a "higher flowing" fuel filter for 99% of honda/acura applications.
I believe aem makes one but I am not sure of how it performes versus a factory filter.
Old Sep 12, 2006 | 08:52 AM
Alpha's Avatar
99.9%
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
Old Sep 12, 2006 | 12:01 PM
DC Crew Member #1
lol ok thanks I was just on their site and didn't see anything but I will keep an eye out. In my book every little bit helps.
Old Sep 12, 2006 | 12:16 PM
Cold_Beer's Avatar
Rockin' 4 more Cylinders
you must be reading the wrong book.
I know guys making 300+whp on stock honda filters....Unless your getting it for the Bling factor, cause you wont see a lick of HP gain reguardless of what you think.
RIP Robert Kolp aka 00ek 4/07
_Jake D
Old Sep 12, 2006 | 12:23 PM
DC Crew Member #1
Well I bought the book at a used store so there are a few pages missing lol thanks for the input though. I just needed to replace it so I figured I might as well get the best for the application which at this point looks like stock will due. I'm looking to be pushing about 225-250 whp so I guess I'll be fine.
Old Sep 12, 2006 | 12:38 PM
mtber's Avatar
Factory honda fuel filter, factory honda distributor, factory honda spark plug wires etc... Factory honda parts work better then 90% of aftermarket parts man
Old Sep 12, 2006 | 01:00 PM
DC Crew Member #1
I was actually looking into the MSD ignition and like the ss coil with NGK plug wires and NGK iridium plugs as a start. I want to run a turbo setup with like 8 lbs because I want this to still be a reliable daily driver. I think I should be able to reach approx. 250 hp with this setup and a few other things.
Old Sep 12, 2006 | 01:03 PM
Cold_Beer's Avatar
stock honda ignition is good for 500whp +
_Jake D
Old Sep 12, 2006 | 02:02 PM
Janky99's Avatar
Honda Guru
I made 542 whp on stock ignition.
