Clutch Question
Old Sep 10, 2006 | 06:13 PM
Ringo_'s Avatar
Unhappy Clutch Question
So i got a hydro clutch and my fluid keeps draining ALOT...It drains it completly empty and have only about 1 inch of pressure on my pedal...do i just need a new clutch or does it have something to do with my slave cylinder?
Old Sep 10, 2006 | 06:47 PM
aznkhmerracernza's Avatar
You might have a Bad seal in your Clutch Master Cylinder or somewhere else. It's about time to get a new one and fixed.
USS MAINE BLUE CREW, BANGOR WASHINGTON!!
www.myspace.com/maknpanna
Hater's Avatar
Free base cocaine
check for puddles under your car
you probaly blew somthing
Old Sep 10, 2006 | 06:48 PM
If your Fluid is Dark. Time to change your Fluid. Contaiminated PAG brake fluid is bad.
Old Sep 10, 2006 | 06:49 PM
Ringo_'s Avatar
well i havnted seen any puddles wich is y iam thinking iam burning it or something...i know i need a new clutch and iam well over due for one so coudl that be sucking up my fluid?
Old Sep 14, 2006 | 11:46 PM
If it's draining A LOT, clean the motor at the spray wash; look for where the fluid is present; from one end of the hose to the other. It will show up somewhere if it's really draining. Wrap a rag around the hose the full length, if the fluid is hard to see. The clutch will not suck up/affect fluid level/leakage.-Bob
Old Sep 15, 2006 | 01:21 AM
elwrestler03's Avatar
MrB18crx
Or you can use parts cleaner to clean the motor if you dont want to spray it.
wb_map3
ta b real witcha i actually 1 a spellin b as a jit n i alwayz got 100 percent on all my spellin test even got da bonus wrds rite and got an a in english 1-4 in high skool so lets leave the post ta buying and selling parts iight
Old Sep 15, 2006 | 07:56 AM
GradeA_TireFryer's Avatar
All American, rice eater!
look inside you car, where the pedal goes thru the firewall, pull back carpet - is it wet or do you see any fluid? - if so you master cylinder is bad-
I would change it - the slave and clutch at one time!
Pirate Customs
Sound, Security & Style..... anything for your ride
Old Sep 15, 2006 | 10:10 AM
chi town brat's Avatar
! Ne shab'rud'ni !
+1 for checking behind the carpet
my slave cylinder on my d16z6 coupe is leaking, it is at the front of the engine right in front of the tranny, if that makes any sense.
its 2 or 3 bolts and a 10 mm flared wrench to replace the part and damn i haven't done it yet.
Old Mar 25, 2014 | 10:17 AM
diagnosing a clutch problem
