Type-R Door Panel Window Switch...
Old Nov 26, 2006 | 10:26 PM
Kamikaze's Avatar
Li-Neezy™
Default Type-R Door Panel Window Switch...
Just went to type-r door panels, and when I try rolling up the passenger window, it doesn't work, neither does the mirrors. Do I need to take my old window switch out and put those back on or what? Is there any difference with the USDM and the Type-R switches?
Old Nov 27, 2006 | 10:22 AM
skunk2racing97's Avatar
UF Mech/Aero Eng
A) honda would use the same wiring for all versions of a mass produced car, so the wiring must be the same/very similar
B) as long as the switches work, and the windows/mirrors are installed/wired properly, they should all work together.
C) if i were you, i would take both sets of switches, set em next to each other, get a VOM, and do some testing to determine if they were the same and if they function properly
Old Nov 27, 2006 | 10:42 PM
Kamikaze's Avatar
Li-Neezy™
Thanks, I could've sworn I saw someone make a post like this about them before, guess not... Thanks though skunk2
Old Nov 28, 2006 | 04:38 AM
UF Mech/Aero Eng
well, someone def may have...
i've been wrong on occasion
Old Nov 28, 2006 | 10:18 PM
+1 skunk2, especially the volt-ohm meter.-Bob
Old Nov 29, 2006 | 06:47 AM
Kamikaze's Avatar
Li-Neezy™
K will see A.S.A.P, if anyone has had this problem also, please post up.
Old Nov 29, 2006 | 12:19 PM
zuir18's Avatar
should plug up and go fine.Thats how mine worked but maybe the switches are bad or maybe you blew a fuse?
Old Nov 29, 2006 | 02:29 PM
Kamikaze's Avatar
Li-Neezy™
Thanks, I'll check the fuses, if that's not it, I'm just going to switch in the LS window switch.
Old Nov 29, 2006 | 05:06 PM
lzylst's Avatar
did you overlook the MAIN switch ?
Vance @ 863-604-2139 for any questions
Old Nov 30, 2006 | 07:16 AM
Kamikaze's Avatar
Li-Neezy™
all the controls on the power switch work except for it rolling down the passenger window and the mirrors. So, I guess I COULD HAVE...
