E-Brake light won't go off
Old Sep 8, 2006 | 05:05 AM
icegsr's Avatar
Default E-Brake light won't go off
Yea like the title says. Even with my e brake down, the light won't turn off. Is there a sensor somewhere I should look at? Thanks.
Old Sep 8, 2006 | 06:11 AM
00ACCORD's Avatar
SPEED DEMON
that happened to me, at that time I needed to change my brakes
Old Sep 8, 2006 | 06:13 AM
Derka's Avatar
TR Balla Donor Supreme
Check your brake fluid. When its low the light stays on
1998 crv daily beater
Old Sep 8, 2006 | 06:29 AM
chrisdevasher's Avatar
ya when i get in my car in the morning and start driving mine is on for a few minutes then after using the brakes a few times to slow down it turns off. but i also need to replace my brakes too so that could be a reason why.
Old Sep 8, 2006 | 06:55 AM
Jay's Avatar
Jay
Janky
Aim: o JankyJ o
http://jankycrew.com
Old Sep 8, 2006 | 07:01 AM
Brownsound's Avatar
Dude.. thats awesome.
Hey the same thing started happening to me last week!
At first it only came on when I started the car, then it would go off after a minute, only returning when I was accelerating.. wierd.
Now, it is on all the time, so I dunno what the deal is..
Old Sep 8, 2006 | 07:45 AM
Gringo003's Avatar
B.B.C
+1 break fluid
Old Sep 8, 2006 | 07:53 AM
sxecrow's Avatar
EG2 CRX
+1
Old Sep 8, 2006 | 08:26 AM
mondo375's Avatar
my g/fs teg does this. Ive read on h-t that its either
1. Brake fluid is low like mentioned above
2. The sensor on the cap where you put brake fluid in is bad.
or 3. Loose connectiong somewhre in ebrake area.
To test number 2 I read you just unplug the connector(s) near the top bo the cap that are wrapped in rubber. If the light turns off when unplug this the sensor in the cap is the problem. This problem just started for her so its somethign im reading up on so i can fix it this weekend.
Old Sep 8, 2006 | 09:20 AM
nickscivicsi69's Avatar
Drive it like u stole it
+1 for break fluid... Had same prob that solved it
Originally Posted by Flaco_GST
"If you don't set goals for yourself, you are doomed to work to achieve the goals of someone else."
TR "Rep for Bumpin" CREW MEMBER #69 A.K.A #1TR "EG" CREW MEMBER #21 A.K.A #69
THE HATCH IS FOR SALE!!
"There’s a difference between knowing the path and walking the path"
