car troubles
car boggs when i slam the gas driving or in neutral and idle drops off and car shudders i have changed the cap and rotor and spark plugs i dont know what else to do help please the car is a 93 da teg
check ur injector filters and ur fuel filter and shit like that
9/13/06-R.I.P. Kevin aka Slo Si, you will be missed
06-07-2006 01:47 AMSlo_Siwhen the spinnin ends, the bullshit ends...
xbox 360 gamer tag slohatch93
Jap Tuned!!
Jap Tuned!!
jus try it cause when ur cruising theres not a steady vacuum on the fuel pressure and when u got a load on it its not getting enough fuel
Jap Tuned!!
Jap Tuned!!
make sure that all the vacum lines are connected, does the engine light come on at all?
TR "Rep for Bumpin" CREW MEMBER #69 A.K.A #1TR "EG" CREW MEMBER #21 A.K.A #69
THE HATCH IS FOR SALE!!
"There’s a difference between knowing the path and walking the path"
no engine light and also when your sittin at idle and you push the gas all the way it like sputters and rev's and then drops it sounds like i have a huge racing cam in there you kno that blum blum blum sound like the funny cars like that but its more spaced out then blum blum its more like blum.....blum.....blum like dat but i will check the fuel filter and the injector filters
injector filters are little tiny screens that sit on top of the injectors in the fuel rail. if you pull em out you will see the filters on top, little black plastic cone that sticks into the injector.
thanks guys im going to try that cause i jus got this car like a month ago and i havent touched the motor at all and it jus started doin this so i changed the spark plugs and cap and rotor so i thought it might be the wires but i'll try the filters and if anything ill clean them out really good and put them back in if not that then i kno its the injectors
