Idleing problem
Old Aug 25, 2006 | 08:55 PM
sm6989's Avatar
Rick Rollin
Default Idleing problem
alright..I got a 90 teg. I was driving it earlier, running fine, then I stop at a light and im idleing at 3k.. Thought maybe something was sticking so I put my foot underneath the gas pedal, push up and then the car will start idle surgeing from 1-2k..give it gas again then its back to 3k.. I dont know..any guess's what it could be? what I should check?
I Rick Roll in your sleep
Old Aug 26, 2006 | 05:45 AM
mondo375's Avatar
might not be the same as your problem cause mine didnt hold itself rev/hold it self thta high. But i had a vacuum leak caused by a rip in my intake manifold gasket *not saying yours is* and i had a surging idle and every now and then it would hold itself at 3k whether i ahd my foot on the gas or not. So in gear it would be driving itself lol. Guess what im saying is check for vaccum leaks.
I used this site Honda-Tech.com: Idle surging...Hunting idle....Lets fix this now.
as well as this one Bad Idle Troubleshooting
GL!
Thanks,
Mondo
Old Aug 26, 2006 | 12:19 PM
sm6989's Avatar
Rick Rollin
I found the problem..some little mapping sensor or something by the manifold..Cost $350 at advance..so I guess I'll goto cophers and pull one for $2.00 =P..unless someone has one and could save me the hassle of going over there tomorrow.
Thanks for your help tho man
Old Aug 26, 2006 | 01:33 PM
hondachris1994's Avatar
hatchback1994
I bought my map sensor at napa for $75 that was the cheapest I found it....but if I were u I would post WTB map sensor in the H/A parts for sale im sure someone has 1 layin around and most map sensors are interchangeable
Old Aug 26, 2006 | 02:26 PM
sm6989's Avatar
Rick Rollin
would that make sense for it to be the problem though?
Old Aug 26, 2006 | 02:49 PM
mondo375's Avatar
how did u come to the conclusion it was the map sensor? Just wondering. Id hate for you to buy a new one or used one when it wont solve the problem.
Thanks,
Mondo
Old Aug 26, 2006 | 03:02 PM
hatchback1994
Thanks,
Mondo
I agree when my map sensor went bad it idled a lil over 1k and it ran really rich and my CEL came on....Is your CEL on? If so check the code first, cause it sounds like it could b the FITV or IACV
Old Aug 26, 2006 | 08:59 PM
sm6989's Avatar
Rick Rollin
Took the vaccum line off of it and then the idle went down to 1k.. has a miss without it but isnt idleing at 3k like it was. so figured it would be that...
Old Aug 26, 2006 | 09:14 PM
EXtreme7200's Avatar
loves beer!!!!
it must def be a vacuum leak
Old Aug 26, 2006 | 10:21 PM
I have a different setup than you, but I backed off any screw that could keep the throttle open, sprayed generously with PB Blaster, worked the throttle several times and set the screws back as original.
Cleared it up, but other people have some good ideas, also.-Bob
