honda crx clutch/electrical ?s
Old Aug 18, 2006 | 04:27 PM
elwrestler03's Avatar
MrB18crx
Default honda crx clutch/electrical ?s
honda electrical/clutch broblem?
Ok here is the deal with the electrical. I bought a new battery this was about a year ago because I thought my old one was done. So I put the new one in and bam runs nice and strong. Two/three days later after sitting all night car wont start. So I jump it and bam it works . I drive to work and let it sit for about 8 hours and still starts. So that means ( I think) that its getting charged but that there is some type of draw. So I buy a volt metter and have my car off all doors closed and check for a draw. no draw (it seems) All in all I have no idea whats wrong I have checked fuses, alt check by my friend and discount, Alt connction wires, battery connection wires, Only thing I havnt checked is the main fuse I think that is what its called? Oh and since this started my gauge lights have been flashing. Please help.
Clutch question. I need a little more life on my clutch and its worn bad is there any trick to this? and I found a six buck clutch.This is it is it a good buy does it have good life? and can I use my own pressure blate and etc?Sorry for the long post but Im trying to get thing done on my own to save monet that I dont have much of. Any help would be greatly appreciated.Thanks......Matt loyal TR member
for sale act 6 puck clutch used with 5,000 miles on it need it gone asap it is for a b-series askin 50 o.b.o. lemme know call thanks ricky
wb_map3
ta b real witcha i actually 1 a spellin b as a jit n i alwayz got 100 percent on all my spellin test even got da bonus wrds rite and got an a in english 1-4 in high skool so lets leave the post ta buying and selling parts iight
Old Aug 18, 2006 | 08:22 PM
Big Chris's Avatar
tampa car scene
This belongs in honda tech.
Old schooler.
Old Aug 18, 2006 | 11:32 PM
mtber's Avatar
Try another battery or have the battery tested for a fucked cell.
Have the alternator tested just to be sure its actually fully charging your battery.
I am guessing your running an all motor setup. If so, that clutch is overkill for your setup, I would not recommend it...
Old Aug 19, 2006 | 08:55 AM
MrB18crx
I had the new one I got tested and they said there was a bad cell and I got a new one and the same thing started with that one. Ya its basicly stock intake, exhaust, fuel press reg, skunk 2 intake mani, chipped ecu. Why would this be bad for my setup? Thanks for any advice. Oh and it is in honda tech but they didtn reply so I posted in here causr you guys are usualy good about responding.
wb_map3
