LS pistons in a GSR?????
Old Aug 10, 2006 | 06:30 PM
TurboJdmEk's Avatar
is on blocks...
i was thinking about like 7-9 lbs daily then for the track i wanna jump it up to like 15-17 maybe 20 if the motor permits? what do you guys think ls or forged i was thinking je? anyone got any better suggestions?
its coming...
Old Aug 10, 2006 | 07:52 PM
Slo_Si's Avatar
$200 Motor!
all depends on what your setup is and how much timing you have in the tune...there is too many variables, if you have the money get pistons and rods...should be like 750 for both and then you can boost away....
- Officially Retired....for now...
Old Aug 10, 2006 | 07:57 PM
TurboJdmEk's Avatar
is on blocks...
what about sleeves? its a gsr in an ef obd0...
its coming...
Old Aug 10, 2006 | 08:09 PM
Slo_Si's Avatar
$200 Motor!
stock sleeves will be fine...ICS is making over 500whp on stock sleeves....sleeving a block is for serious power and basically insurance..safety kinda thing...do you have a engine management for your obd0 car? I have the obd0 hondata that im running in my car right now that i will be getting rid of..vtec ecu and hondata box and all....lmk if your interested...
Old Aug 10, 2006 | 08:52 PM
Blown99civicSi's Avatar
EFI Tech/Tuner
We havnt installed LS pistons in a VTEC motor, but I was under the assumption that the valve relief on the LS pistons isnt enough to clear the valves.. I will look into this more, but im almost positive there will be clearence issues with the valves... Thus the reason you dont use the LS pistons in a LS/VTEC unless you clay the motor to be 100% sure.(I could be wrong, but I dont think sooo...)
Modified Racing
Street Tuning & Dyno Tuning the greater east coast area for over 10 years and running!
AEM/HONDATA/MOTEC/FAST/DEFI & More
EFI-101 Certified
(941)628-4988
Old Aug 10, 2006 | 08:59 PM
EFI Tech/Tuner
BTW in stock form swaping the LS pistons in a GSR will net you right around 9:5:1... compression, bit again valve clearence is the problem..
Modified Racing
EFI-101 Certified
(941)628-4988
Old Aug 10, 2006 | 10:28 PM
  #17 (permalink)
YBlegal's Avatar
Broke not Built
call me back mang...
working my way back up...
Originally Posted by JoKiE crx4294
What do i have to prove to anyone?....umm NOTHING!!
Old Aug 11, 2006 | 06:04 AM
  #18 (permalink)
TurboJdmEk's Avatar
is on blocks...
so they wont work due to valve clearance?
its coming...
Old Aug 11, 2006 | 05:27 PM
  #19 (permalink)
EFI Tech/Tuner
Im pretty sure in stock form that they wont work, but hell im sure if you installed a thick headgasket nad used very mild cams you might get away with running them Whatever you do clay your motor when building it to make sure the setup you run still has ample clearence....
I found 1 other post about not using the pistons due to clearence, but will look into crunching some numbers 4 U as hearsay is worthless these days
Modified Racing
EFI-101 Certified
(941)628-4988
Old Aug 11, 2006 | 06:41 PM
  #20 (permalink)
TurboJdmEk's Avatar
is on blocks...
thanks alot for all the info lmk homie!!!
its coming...
