map sensor question
Old Jul 30, 2006 | 06:58 PM
b18civ's Avatar
Default map sensor question
Anyone know if there is a difference between a map sensor found on a 1999 honda civic dx and integra gsr , a 1996 to be particular. I am running the sensor from the civic on the gsr engine, connections are the same, they look similar. The engine even seems to run fine with it. My question is do they both have the same specs in regards to the voltage output at a given vacuum? Just curious if it will make the gsr engine not run up to par as far as power. anyone?
Old Jul 30, 2006 | 07:01 PM
mtber's Avatar
There is no difference.
Old Jul 30, 2006 | 07:02 PM
CRXkid24's Avatar
uh oh
it shouldnt make a difference.
my car gets mad after 5,500 rpm!
cheeSpec tuned!
R.I.P.
Pablo
Lil John
Mario
Old Jul 30, 2006 | 07:30 PM
T4eg's Avatar
same sensor
Old Jul 31, 2006 | 02:32 PM
b18civ's Avatar
Thanks guys, I thought so, but just wanted to be sure
Old Jul 31, 2006 | 02:48 PM
TSX24L's Avatar
I don't see how any map sensor would be differnent, all the map sensor's job is to covert manifold absolute pressure in to a electrical signal to the computer. I know ive seen alot of them go bad from moisture or doing some sorta induction service same as the idle control vavles on honda's.
