b16 block + ls crank and rods= 1.8?????
Old Jul 14, 2006 | 02:17 PM
luvsracin87's Avatar
turbo hhhmmmm?
Default b16 block + ls crank and rods= 1.8?????
correct me if i am wrong but if i were to put the ls rods and crank in a b16 block it would make it a 1.8 right? with the rods(with arp rod bolts) and crank and itr pistons would this motor be better than a ls/vtec?
i havt to rebuild my motor soon and wanted to know wich has more potential(all motor) any input is appreciated. thanks
Steve: (813) 810.4146 <~ call or text
Old Jul 14, 2006 | 02:52 PM
Cold_Beer's Avatar
Rockin' 4 more Cylinders
the problem wiht lS crank and rods in a b16 is that you have to run special pistons....but when done it is the same as a LS vtec, just less noticeable (sneakyness).
a CTR block though they fit right in since the deck height is taller.
RIP Robert Kolp aka 00ek 4/07
_Jake D
Old Jul 14, 2006 | 02:54 PM
lzylst's Avatar
interesting info ^^
Old Jul 14, 2006 | 03:03 PM
integrex's Avatar
or just find a b17 crank
Old Jul 14, 2006 | 03:09 PM
Cold_Beer's Avatar
or jsut put a b16 head on a ls block.........soooooooo much easier
_Jake D
Old Jul 14, 2006 | 03:23 PM
turbo hhhmmmm?
ok so i will just put a vtec head on my block. i hav obd0 so would it be easier to just get a vtec controllerand obd0 vtec dist. rather than wire it to obd1?
Old Jul 14, 2006 | 03:24 PM
Cold_Beer's Avatar
convert it to obd1, and run crome . anyways whats up with my guage cluster?
_Jake D
Old Jul 14, 2006 | 03:27 PM
turbo hhhmmmm?
i got the cluster $15 if you want to check it out ill be home for another 30min.
do you rember where i live?hit me up 478-6245
-steve
Old Jul 14, 2006 | 03:48 PM
sxecrow's Avatar
EG2 CRX
Would the difference in deck height matter at all?
Old Jul 14, 2006 | 04:05 PM
Cold_Beer's Avatar
yes, the fact that a "normal" B series piston would stick out the block way to much and would hit the head. Now a custom piston w/ a lower pin height or what ever will sit lower and BAM you got a LS/vtec in a B16 casing
_Jake D
