car not running right... help!
Old Jul 16, 2006 | 04:20 AM
Michael.'s Avatar
I'm a Photographer!
hmm ok then...are you sure he built this thing right?
Old Jul 17, 2006 | 04:43 PM
civicSi07's Avatar
so today i took out my vafc thinking there were maybe some loose connections somewhere throwing something off. everything is wired back correctly without the vafc now, and i also changed the fuel filter, and adjusted my throttle, because that was sticking.
i am still running rich, and the car doesnt drive any better. i need help!!!
1992 Honda Civic Si: SOLD
2003 VW Gti 1.8t: SOLD
Most recent: 88' B16 Turbo CRX: Totaled
PM me if you know me!
Old Jul 17, 2006 | 05:28 PM
civicSi07's Avatar
ok so i just went and reset my ecu by taking the battery off. i hooked it back up, and let the car idle for a min. i checked my codes again, and now all the codes im throwin are 14, and 10 which are the iacv and iat still. my idle jumps up and down when the car idles, so ill bet the iacv and iat are messing up the fuel mixture, and thats why i smell gas, and my car runs like crap. its givin it too much gas.
Old Jul 17, 2006 | 05:58 PM
Michael.'s Avatar
I'm a Photographer!
then find those plugs/switches and switch them?
Old Jul 17, 2006 | 06:07 PM
civicSi07's Avatar
i tried but didnt get anywhere. nothing much changed. i may go up to honda tomorrow and have jason give me a wiring diagram of which color wires go to which. ill switch em out to the right ones, reset the ecu, and hope im not throwing anymore codes.
Old Jul 18, 2006 | 04:06 PM
CIVICS55's Avatar
You Have Your Iacv And Iat Plugs Mixed Up ,those Are The Only Two Sensors With The Two Prongplug So Switch Them Around And That Should Do It ,if Not Tou Said There Is Wining ,eexplain
Old Jul 18, 2006 | 04:47 PM
  #17 (permalink)
civicSi07's Avatar
woohoo i just got it running! iacv had the wrong connector. i called honda this morning and found out the wire colors. so now i have the throttle adjusted pretty well, and the idle adjusted pretty good. the motor runs awesome other than i still have the iat code, and the wining.
as for the wining, i believe it to be a belt a little too loose. alternator belt seems to be just a bit loose. i will tighten that up in the morning. (pwr steering and alt. belts are brand new, so that could also be part of it).
other than that im happy that i got it running, and will keep the thread updated about the wining.
