radiator question
Old Jul 10, 2006 | 05:57 AM
SilvCivOn17s's Avatar
cause the whistle goes...
yea, im running a stock d15 radiator on my b16a and it does the job
R.I.P. Brian Nichols 02/07/1989-11/23/2008
Old Jul 11, 2006 | 03:36 AM
tranceologist's Avatar
TR Shop Mod
Originally Posted by accord95
here is a stock d16 half size radiator on a b18 type-r motor
accord95 thats a special hose correct ? i c its ribbed for added pleasure lol. is it a different size at the other end or did u just tighten it like a mofo ?
Old Jul 11, 2006 | 06:13 AM
danaintampa's Avatar
Put a ring of jb weld around the neck if you want a normal civic radiator to match a b18 hose, or use a smaller piece of hose on the neck as an adaptor and slip the larger hose over it. Or use an si radiator, if the neck is the same diameter as the b18, which i would assume is true but not positive.
Don't overtighten the clamp to make it fit. Won't work well, if at all and you might break it.
Old Jul 11, 2006 | 04:06 PM
TR Shop Mod
now we're talkin. thanx for the idea. this would aid as a flared piece if i get ur theory correct ?
Old Jul 11, 2006 | 08:28 PM
accord95's Avatar
USMC
Originally Posted by tranceologist
accord95 thats a special hose correct ? i c its ribbed for added pleasure lol. ?
haha
its a hose cover, thats not the actual hose
if i were you i'd just take the coolant hose from your b18 and test fit it on the d16 radiator. i bought the car like that, but i'll find out if the guy did anything special to make it fit.
TR happily married crew-member #2
___________________
Originally Posted by Troux
This is the internet. You're just supposed to talk up whatever you do know as if you're a salesman for it. i.e. I drive a Supra and a Corolla therefore 2JZ is the greatest and so is the 4A and I don't care about anything else because it's all crap since I don't have it. I also have a stack of $20 bills in front of me, therefore 20>50 and 20>100 and 20>1000. $20 bill FTW.
Old Jul 12, 2006 | 11:09 AM
sxecrow's Avatar
EG2 CRX
Avoid those radiator hoses with the coils inside as they will rust and you'll end up with rust floating around in the water jacket. Not so fun.
Old Jul 13, 2006 | 03:22 AM
  #17 (permalink)
TR Shop Mod
well ive seemed 2 fix the radiator neck leak, but wen ever im on it hard creating pressure in the system, the driver side of the windshield is getting a shower of coolant ? wenever i pull off the road i cant find anything ? is there any coolant lines on the driver side that i cant see that may b leaking
Old Jul 13, 2006 | 09:04 AM
  #18 (permalink)
I think the neck might be shooting water out the front grill and blowing back onto the windsheild. There are no hoses on the driver side.
Old Jul 14, 2006 | 12:49 PM
  #19 (permalink)
TR Shop Mod
everything looks dry around the neck tho ? nuthing on the front bumper or hood ? i cant even see any damp areas on the inside of the hood ? whodini coolant u think ?
Old Jul 14, 2006 | 12:55 PM
  #20 (permalink)
zip tie paper towles around the hose clamps and a few areas in the engine bay, go run it hard and check them.
