Car falls on its face
Old Jul 4, 2006 | 12:42 PM
Frankie Figs's Avatar
Too Much is ALMOST Enough
Old Jul 4, 2006 | 12:57 PM
TampaTraps's Avatar
get big or die trying!!
don't know if you said anything about reseting the ecu but do that. if you still have a problem, check all the injectors make sure the connection is strong, if good move on to all grounds, if good then check plugs. if good, then check the ecu wires have they every been cut? really what i am getting at is check everything lol.
that's president hussein obama to you :gordy:
Old Jul 4, 2006 | 01:45 PM
mustwonder's Avatar
GY-16P
i will go run through everything in alittle bit and check back around 7 and let you all know whats going on im stumped because it drove fine i parked it went into wal-mart came out and it started this shit. thanks for all the help
Old Jul 4, 2006 | 02:44 PM
Jaso0on's Avatar
Is now ballin!
Originally Posted by Derka
tps?
+1, I'm almost positive this is the problem...
RIP Kevin (Slo_Si) Gonzalez - 09/13/2006
Old Jul 4, 2006 | 03:24 PM
SmokinS13SR20's Avatar
That ginger...
But how would the TPS be the problem if it revs fine out of gear?
Old Jul 4, 2006 | 04:48 PM
DemonCivic's Avatar
have you checked the fuel pressure and volume? if the pressure is low and the pump isnt producing the volume, under a load the engine will react as you are describing.
Old Jul 4, 2006 | 05:24 PM
  #17 (permalink)
mustwonder's Avatar
GY-16P
i just dont understand when it isnt in gear it revs and idles perfect everything is great but as soon as it goes into gear and starts to move it just like stops getting the fuel to go. ive went thru the injector clips and tried to check for leaks as best i can and checked the harness. idk ill look at it tomorrow
Old Jul 4, 2006 | 05:27 PM
  #18 (permalink)
Derka's Avatar
TR Balla Donor Supreme
why dont you bring it by, i have plenty of extra parts to try
1998 crv daily beater
Old Jul 4, 2006 | 06:29 PM
  #19 (permalink)
DemonCivic's Avatar
put a fuel pressure gauge on it and check it, lmk what the pressure is. i just had a car with very similar symptoms, checked the pressure and it was a little low, did a volume check and it was way low. put a new pump in it and now it hauls ass. g/l
