hesitaion while in VTEC?
Old Jun 30, 2006 | 08:00 AM
YBlegal's Avatar
Broke not Built
Default hesitaion while in VTEC?
ok i have a 90 EF hatch with a JDM GSR(B18C) has ITR cams and omni power valvetrain, skunk2 intake mani. DC 4-1... car has been converted to OBD-1 using a complete harness out of a 93 DA TEG. and has a VAFC-1 only running VTEC ECU is a P06 with GSR maps and converted for VTEC, but ive also used a P72 ECU and same results, and i also tried a new dizzy...oil pressure is fine, VTEC sol. screens are clean...
ok onto the problem....car runs great untill 300-500rpms into VTEC, VTEC is set at 5200, now if i disconnect VTEC it runs fine all the way to redline wich is 8600rpms....i dont know how to explain what its doing, but its kinda like a hesitation/miss fire, i dont know what to call it....
anyone have any clue what might be the problem??
working my way back up...
Originally Posted by JoKiE crx4294
What do i have to prove to anyone?....umm NOTHING!!
Old Jun 30, 2006 | 10:27 AM
TIM TIM TIM's Avatar
could be worse
mines pretty much doing hte same... mine is getting lean as hell for some reason.. i would try to hook up a wideband or somthing nad see if your having the same problem
aim:because tim said
Old Jun 30, 2006 | 10:51 AM
YBlegal's Avatar
Broke not Built
shit sux.....runs great with the VTEC sol. unhooked...
Old Jun 30, 2006 | 11:58 AM
stockCRXsi's Avatar
I wnat to say that it might be in your wirring or maybe the computer, but you already tried a different computer. to me, it doesnt sound like a mechanical problem, since it runs fine without VTEC and with VTEC you said it miss fires and hesitates. does it also back fires?
Old Jun 30, 2006 | 12:03 PM
SmokinS13SR20's Avatar
That ginger...
Check your plug gaps.
Old Jun 30, 2006 | 01:35 PM
YBlegal's Avatar
Broke not Built
it could be something in the wiring, i got a pin-out and diagram for the harness im gonna go through everything....no backfiring, and its not really a missfire, it just feels sluggish and hesitant....
already done that, ive had 3 sets of plugs in it....same thing...
Old Jun 30, 2006 | 02:39 PM
That ginger...
Hmm, if the ecu is chipped, have a tuner check out the fuel maps for the secondary cam lobes and make sure they are ok.
Old Jun 30, 2006 | 03:14 PM
could be worse
check the a/f... mines doing the EXACT same thing... its getting lean as hell when i hit vtec.
Old Jun 30, 2006 | 03:48 PM
YBlegal's Avatar
Broke not Built
[QUOTE=TIM TIM TIM]check the a/f... mines doing the EXACT same thing... its getting lean as hell when i hit vtec.[/QUOTEi dont have access to a wideband...so i dunno what the a/f looks like...
already did that....had a new map burned and same thing...tried a stock P72(GSR) and it ran a lil better but for some odd reason, 1st/2nd gear goes to 8k+ but when i go into 3rd/4th it his the rev limiter at 6500....wierd shit
Old Jun 30, 2006 | 04:03 PM
could be worse
i understand you tried a new comp.. but have you checked the a/f of your car running? we have used 2 diff computers on my car and its still doing the same thing also.. im not forcing, it just sounds like my problem.. i know what my prob is, just not how to fix it lol
