ls/vtec engagement problem
Old Jun 27, 2006 | 06:05 PM
Janky99's Avatar
Honda Guru
oh btw robert.. there is an O-ring inside of the head that if it is not there it will not have enough oil pressure for vtec to pop. I know when this head was on my block vtec popped. You need to check for the o-ring. -Ben
Old Jun 27, 2006 | 06:13 PM
methree's Avatar
loser x.x
gotcha. where is it located at?
i dont know why people dont take me seriously....now wheres my crack pipe
Old Jun 28, 2006 | 09:27 PM
Janky99's Avatar
Honda Guru
This is in the lma's on the top of the head.. i think its on #2 or #4.. i can't tell without the head in front of me. anyway's B series FTL K series FTW.
Old Jun 29, 2006 | 12:14 PM
juiced2ndgenteg's Avatar
you mean the o-ring in the third cam cap with the dowel pin? That will not cause vtec to not engage. I have ran heads with them and without them, dosn't make a difference. Also the LMA's will have NO effect if vtec pops or dosen't. They will just cause valvetrain noise. Get it right.
Old Jun 30, 2006 | 07:25 PM
Janky99's Avatar
Honda Guru
Get it Right? I have it right... If you read this again.. no where does it state that the LMA's will cause vtec to not engage.. It is the O ring in the lma's that will have an effect on it. If this is not in it could cause you to loose oil pressure... causing vtec to not engage. Thanks -Ben
Old Jul 1, 2006 | 09:18 AM
Have you ever seen a LMA? they don't come apart and they don't have any o-rings. THERE IS NO OIL PRESSURE FED TO THE LMAs!
Old Jul 5, 2006 | 10:16 AM
  #17 (permalink)
Old Jul 5, 2006 | 12:46 PM
  #18 (permalink)
Janky99's Avatar
Honda Guru
Yea I was wrong.. I apoligize for the incorrect info.. I for some reason had a single cam on my mind.. and I was thinking the LMA's when on the top. I'm sorry the O-ring on the cam cap could cause the problem.
Old Jul 5, 2006 | 02:11 PM
  #19 (permalink)
cleaned it up. Thanks.
Old Jul 5, 2006 | 08:00 PM
  #20 (permalink)
brax90si's Avatar
U are running a pr4 ecu? If you are running a vtec ecu is the speedo working? LOL I know my vtec on my b16a wont work off the ecu cause my VSS is bad(vehicle speed sensor) Just wondering. Carry on.
-Brax
