Since when do I tune 200 whp turbo cars ?
on
Originally Posted by DONT SLEEP
OWNED bitch....... jason i thought i was the only one who though he is a bitch. lol hahahaha jason ur the man.
i at least know if i want a turbo teg with 200 whp i can always take it to vega for a tune. HAHAHAHAHA
Blown99civicSi good shit on the tune man. i cant wait to go for a ride in it.i know christian is happy. keep up the good work and maybe some of his nutswinger will see the light and go to a real tuner
What turbo teg have I tuned with 200 whp? Christians? Aka gysmo310 ?
I did NOT tune his car, he brought it to me to tune it on a new turbo assuming his issue was his blown turbo.
All I did was sync his ignition timing which was synced from when Jason K tuned it. Yet I noticed a problem with the maps being jacked up due to the base ignition timing at the dizzy being maxed out.
I then decided to make 2-3 passes off the wastegate for him to see where we where. The a/f ratios were great but the car was NOT making power. The car sounded like it had a boost leak & it obviously had problems.
Considering we were paying for dyno time & the car was strapped the the dyno I was not going to troubleshoot the issue on the rollers out of Christians pocket...
I also had other customers at the dyno waiting to be tuned that day...
I informed Christian of what I felt the issues could be. I recall informing him to install another dizzy after he pressure tested his charge system. He never got around to it....
So now... I am a shitty tuner because I tried to save him money ?
I am a shitty tuner because his car made 200whp off the wastegate with a fucked up dizzy on ANOTHER tuners tune (Jason K)?
You must be very intelligent.
If there is an issue with a vehicle on the rollers, I always pull the vehicle off the dyno so the customer does not have to pay for the dyno time.
I have always tried to save my customers money in the past & will continue to do so.
If you felt I should have troubleshooted the issue on the spot at the rate of $200 per hour, you are simply an idiot.
Thank You,
John Vega - Phearable.net
