h series question
Old Jun 8, 2006 | 04:14 AM
dsmpmpn8ez's Avatar
Default h series question
im doing a h22, i did the manual tensioner convertion off of the f series and i dont know what timing belt to use... any idea's?
Old Jun 8, 2006 | 05:08 AM
integraman89's Avatar
lost u already???
try both belts... keep the one that fits better... when you loosen your tensioner you should be able to put the belt on, and when you tighten your tensioner... your belt should be real snug but not too too tight... so in your case, unless someone else has already done this and knows the answer, buy both belts and use the one that "better" fits it. then return the other belt.
Old Jun 8, 2006 | 11:05 AM
dsmpmpn8ez's Avatar
ive already tried a h22 and it was way too short
Old Jun 8, 2006 | 12:02 PM
lost u already???
well then try the other... check and see if it may be a bit longer... how much too short was that belt... make a guess... then take it to discount and have them get a few belts that are just a bit longer that that one, but make sure they have the same teeth on the belts.
Old Jun 8, 2006 | 01:04 PM
Blue92ludesi's Avatar
you have to use the h22 belt, the teeth numbers are different.
The H22 belt fits fine. you just gtta know the trick to it.
unbolt the tensioner.put the belt on the tensioner. and bolt the tensioner down with the belt on it, the belt will tension itself cause its such a tight fit.
Honda of Wesley Chapel Crew Member #1
TR 5th Gen Civic CREW Member # 07
TR H2B crew #2
__________________________________________________ _________________________________________________
Old Jun 8, 2006 | 06:39 PM
dsmpmpn8ez's Avatar
that makes alot of sense, cause that bitch almost wanted to fit. thanks for the info
Old Jun 9, 2006 | 08:11 AM
accord95's Avatar
USMC
i dont know if they are the same, but i used a h23 manual tensioner.
TR happily married crew-member #2
___________________
Originally Posted by Troux
This is the internet. You're just supposed to talk up whatever you do know as if you're a salesman for it. i.e. I drive a Supra and a Corolla therefore 2JZ is the greatest and so is the 4A and I don't care about anything else because it's all crap since I don't have it. I also have a stack of $20 bills in front of me, therefore 20>50 and 20>100 and 20>1000. $20 bill FTW.
Old Jun 11, 2006 | 12:18 AM
+1 -Bob
