how do i figure out what parts these are?
I recently got a 96 gsr that is supposed to have quite a bit of mods on it. I plan to go get it tuned pretty soon but want to be sure they parts are there that are supposed to be. to do so i plan to pull the head and check out as much as i can. the things i really dont know what to look for to see if there what there supposed to be are:
Golden Eagle Iron Sleeved GSR Block
40 over je piston
head is races ported and polished
Eagle Rods
ARP Rod Bolts
ARP Head Studs
skunk 2 stage 2 Cams
Skunk2 Adjustable Cam Gears
skunk 2 valve springs
skunk 2 Titanium Retainers
Portflow Valve Seals
could anyone give me a way to find out?????
40 over je piston
Eagle Rods
ARP Rod Bolts
ARP Head Studs
Pull off the pan you can tell if its sleeved , got rods , or pistons etc ..
ARP bolts are stock on Eagle rods
The Skunk2 cams have an M in the casting on the end as far as I remeber and the retainers are a little harder tot ell etc
Hondata saves lives
Hondata saves lives
also, the compression is supposed to be at 12-1, how do i check that? a compression test?
That would be the easiest way ...
12:1 Compression should yield compression numbers over 260-275psi
Hondata saves lives
Hondata saves lives
yeah well everyone who wanted to help me out so much building a honda dissapeard (sp?) when i got one, so unless you know someone that will on there own time come over and look for me, its not an option. sorry i do not want to pay someone some rediculous price to look, when i can take pics of everything and post it here and most likely get what i need.
